So Nikilyn. . . .
For some reason the steps on chemicals after the fill are making me nervous. Getting it wrong.
So when the pool is full of water . . .
No robot for a month
No SWG for a month
No heater for a month
No swimming for ? PB said until he says it's safe.
No furniture in the pool
Bare feet only in the pool for the first 2 weeks
Brushing twice a day when filter pump is set up and continue brushing for 2 weeks. Top to bottom, downward motion. And check and clean the filter for pool dust during this time.
It's what chemicals he'll be pushing. He mentioned TFP is really good but he 'uses a different routine.' PLEASE! Don't confuse me!
I assume the first thing he'll do is add pool stabilizer when the pumps are running. And I know we need to check the levels in the pool. I'm hopping hubby will stop messing with setting up the flower beds and read up on these topics. He's the science math guy. I am not. Give me design and art and I'm golden. I guess that's why I'm nervous over the chemicals. At least we'll get the proper volume/gallons in the pool tomorrow.
Just after pool is filled, record water meter reading again(yes, pic is best).
Subtract it to get the difference. Then subtract what amount if water you would normally use in the fill time period. This gives you best estimate for your pool volume.
Here is the Hydrazzo warranty numbers:
CL 1.0 – 3.0 ppm
pH 7.2 – 7.6
Total Alkalinity (TA) 80 – 100 ppm
Calcium Hardness (CH) 200 – 400 ppm (In warmer climates when water temperatures exceed 90 F calcium should be kept below 350 PPM)
Cyanuric Acid less than 50 ppm
Sequestering 10-12 ppm
It's nice to know others are going thru all this. I'm one that's going to be hand holding. !!
