It looks ok in the pic.
If it’s under 2 - call it good-
watch it for shifting & becoming more out of level- if that happens u may need to do some re leveling.
Hi and welcome to TFP! What a pretty set up you have!
I would like to see the water level without the cover. Can you point out where the low and high levels are please. Right now I say I agree with @Mdragger88 that is looks good from what I can see now!
thank you! I love the set up too but I want it to be safe too. I don’t care if it’s not prefect as long as it’s safe. Your expert opinion is priceless!! Here are the pics:
lower corner (2 and 1/4 inch)
Higher corner, the opposite diagonal corner ( right or slightly above the white trim)
The general rule is that 3 in or more off is unsafe. I think u are within the safety zone but like I said if things change & shifting occurs (due to splashout/erosion) its time to drain & re level. Further reading How to level above ground pool - Further Reading
