- Jul 17, 2023
- 12
- Plaster
- Pentair Intellichlor IC-40
Hi,
My hose keeps springing leaks, even in newly replaced sections. Does anyone have tips on a few points?
Hose length - I see posts which say it needs be long enough to reach the farthest point. Should I measure this from the outlet valve to the pool floor?
Pressure release valve - I see some posts that there are different strengths of valves…but how do I know which is the right one for me?
Hose setup - is there a certain number of ball joints/pivot points I should have? Should the backup jet be in a certain spot (closer to the unit, middle, closer to the outlet in pool wall)?
Should the hose usually float? When attaching I keep trying to ensure it is full of water and has no air by dropping the cleaner in, letting it sink and then submerging the hose working back to the attachment point for the wall, but no matter when the hose seems to want to float up…is this normal or an issue?
Thank you
DD
Thank you
DD
