reggiehammond
- Oct 4, 2020
- 1,546
- Plaster
- CircuPool RJ-60 Plus
You’ll likely be adding a bit less than a quart each addition - the TFP method is to pour directly from bottle, close to the pool surface to minimize splashing. The only consideration is to make sure you’re standing downwind or you’ll potentially get a nasty whiff.I'm a little concerned about using liquid acid. Is it normally just a small amount used at a time?
