Recently had to change the drive assembly on a Pentair VF pump after 6 years. Had some difficulty getting the desired programming.
The pump runs for 12 hours at low output to save energy. But in the afternoon I have it programmed to run at 25 gpm from 12:00 to 13:00, in order to use a pool cleaner.
Here is the problem: Using Feature 3, with the on/off times above, the pump output does NOT change to 25 gpm from the baseline of about 10 gpm. With the previous drive assembly this worked fine.
Anyone know any remedy? Thank you.
