hi all,
i have a two speed pentair superflo pool pump that is failing to prime on high speed.
if i set it to low speed everything seems to be working. However low speed won't work as well in terms of cleaning up the pool
Troubleshooting steps i took already:
1. opened up the pump basket area (or whatever the name is) and cleaned the strainer and made sure strainer is intact
2. i put a screwdriver in there and turned the impeller a few times in case there was debris
3. lubricated the o-ring on the gasket and made sure the area was clean of dirt/debris
4. made sure the basket was full of water before closing
no matter what, my pump is not priming at high speed. i included a video below. as you can see the basket is full with water when the pump is stopped (that always happens). but when you start it, it does not fill up.
is my next step to open up the pump?
thanks in advance!!
0 new items by Michael Michael
photos.app.goo.gl
thanks in advance!!
