1. Is 4 hours per day a normal run time for a pump ? (We are currently running our 1 HP Single Speed 8 hours per day for our 8,000 gallon)
2. Will our Timer from the Single Speed Pump run the Dual Speed Pump without any problem ?
1. 4 hours should be plenty for an 8,000 gallon pool.
2. should be if the timer voltage matches the motor voltage.
With 8,000 gallon you might even be just fine at 2 hours a day.
I've been running only 2 per day the last few months on my 13,000 gallon pool
and the water / pool is still very clean. Possibly my 1.5 hp filter motor is over kill.
those pics are showing small and can't make out the model of the timer.
what model timer is that? We can derive the voltage it is from it likely.
No that is not correct. Read the pump run time study in my sig. 2 hours is all you need for water quality more for debris cleanup.
Possibly. If you have a large pool with a small swg, you may need more run time to generate the chlorine you need.
Judging by the timer label, thats a 230volt timer.
why are you running a 40k swg in an 8k pool? why not the 20k?...won't hurt anything just costs more.
For just the swg, you could probably generate enough in 30 min.
Over time, the larger swg costs less.
you need to make sure the motor is wired the 230v way.
ah...didn't know that.
More than enough. But you may find it is not enough to keep debris out of the pool.So, running our pump for 2 hours per day would be plenty in order to generate enough chlorine with this SWG ?
