I'm currently servicing a heater for a customer that won't ignite. It will run through 1 cycle of trying to ignite, blower kicks on, gas valve opens, I can smell the gas but no ignition. The service heater LED comes on and then locks out the controls. The AGS light on the back of the control board lights up also.
I started with replacing the hi limit and AGS Sensor with no luck, then tried the Thermistor, pressure switch and ignitor. Also tried bypassing the AGS with the same symptoms. The fenwall isn't blinking or showing any codes. Starting to get worried it needs a new board. Any ideas?
