Currently my VSP runs at 1050 for about 1/2 the total hours , low speed and my suction vac does not move. Runs at 2800 rpm 1/2 the time and that is when the suction vac does its work. Since I am getting a robot vac and will not need the vac is there a recommended speed to set for my high speed on the pump ? I know when I heat the pool 1050 rpm will be good enough to allow the heater to run - Also my hot tub runs at 2850 rpm when it is going - Was not sure how much of the 2800 is needed without the need to drive a suction vac going forward -
thanks
thanks
