Pentair intellichlor and easytouch
Just as a side note, your SWG transformer does not have a breaker, i suggest you add one.
Isn't the grey breaker in the lower right of the upper panel the IntelliChlor breaker?
And the Intellichlor transformer is fed by the pump CB.
img_3662-jpeg.579697
Z,
The SWG transformer is wired to the Pump/Filter relay and does not need its own input breaker...
That said, I personally have one, so that I can completely shut off the SWCG in the winter.
The hardest part about adding the Water Temp probe, is drilling the hole.. You need a drill and the right size drill bit. Everything else is very easy.
Reactions: Flying Tivo
