B,
When the pump is connected to an automation system the pump's display will say "Display not Active".. I am guessing here, but assume it will say "Display not active" showing it is connected to your IChlor, but then switch back so you can run your pump. I have no clue what that cycle time might be..
I suggest that you program your pump for all the speeds and times you want to run and THEN connect the IChlor.. In theory, the pump should run your programming, no matter what the display says..
We don't see many IChlor installs, so once you get it running we would appreciate your feedback on how it works and what all you needed to do to get it to work..
The IntelliFlo is a great pump, but even though it will work standalone, it was designed to be controlled by a Pentair Automation system.
