- Jul 17, 2020
- 42
- Fiberglass
- Pentair iChlor 30
Let everything settle in over night before turning the pool on. Turned on and......one small leak in the drain cap of the new filter. Took the cap off and used some of the magic lube on o-ring and looks good now.
I think I can say at this point things look pretty good. No more air bubbles in the basket even at higher rpms. A small one forms at lower rpms but it’s so much smaller and clears when bumping up the rpm. Filter psi looks great (near 0 at 1200 rpm, 4 at 1600 and 11 at 2600).
Probably not the best replumbing job but tried to make everything work and make sense. I redid the inlet with a new 3 way valve and 90s that fit instead of it being completely skewed and kinked out.
Going to let run for the day to check for leaks later but so far so good. Thank you all for the continuous help! Also it’s so nice having an actual air relief valve!
