BWC,
The flow switch is definitely a safety device, but maybe just not the type of safety device you are used to seeing.
The IC40 has two safety "features".. The Primary safety feature is that the cell does not get any power when the pump is not running. In your case this is because your automation does not send any power to the cell if the main pump is not being told to run. (Sounds like this is working as it should)
The Secondary safety features is the flow switch, if there is no water flowing through the cell the flow switch shuts the cell off so that it can't make chlorine.
As long as the Primary safety feature is working, then it does not matter if the flow switch is working. But here is the issue. It is very possible for the automation to tell the pump to run, but that the pump fails to run. In this case the cell would get power without any water flow.
It is your pool, and you can run it anyway you want, but I would never recommend shorting the flow switch other than for a quick test.
I agree with Marty, running your main pump at 3450 RPM is just crazy!!!
I too would remove the tab feeder and move the cell so that it has at least a foot of straight pipe after the 90..
