Pentair freeze protection stays in spa
Chrisplus4
Active member
Jun 9, 2020
32
College Station, TX
Pentair Intellichlor IC-40
My pool is in freeze protection but only runs the spa and is not switching back and forth. I have freeze protection “on” spa and pool. Is there a different setting I should change. Pictures for reference. IMG_3784.pngIMG_3785.pngIMG_3786.pngIMG_3787.png
Anyone know why in freeze protection my pool stays in spa side and does not rotate. I made sure in circuits thatfreeze protection is in for both spa and pool mode.
That an IntelliCenter?
What firmware version is it running?
Have you talked with Pentair Support?
Looks like it is setup correctly. I would reboot the panel on the side of the house and see if that does the trick. Its worked for me a few times when the system was acting wonky. If that doesn't work, I would call up pentair.
If all else fails you could mess with your valve settings and just let it run so that the pool and spa pipes have water running through them, or just throw in the towel and winterize.
Try upgrading to 2.026 from the Pentair website using a USB stick. Lots of bugs are fixed.
  • Significant bug fixes in Logic and schedules, Freeze protection, Pool cover, Heaters, Pumps, Sanitizers, Lights, Setup wizard, Security, OTA, Login.
