Pentair FNS Plus Filter DE amount
jakie411
6
pa
Hello Everyone! Would someone please help me determine how much DE I need to put into this Pentair FNS Plus filter. The label has torn off. Only number I found P/N 190029 REV. G. I attached some pics of the label and the filter. Thank you so much!
There is no good information on that part number available.
I'd call Pentair Technical Services at 800-831-7133.
You add 80% of the amount after a backwash - 5 lbs.
100% of the amount after a full breakdown - 6 lbs.
You'll have to measure the volume of the scoop. One pound of DE is equal to about 48 fluid ounces. My 36 oz scoop is equal to about 3/4 lb.
You can add it later...no worries.
I bought the
Blue Devil D.E. Scoop with Handle​
My filter needs 6 lbs of DE. So should I put in 12 scoops of DE after a full breakdown?
That scoop looks to be a 1lb size. So, I would think you would need 6 scoops after a full breakdown. Why are you thinking it is a 1/2lb scoop?
I got a little confused with the table attached. It say no. of 1lb coffee cans = 12. According to blue scoop description it is supposed to hold up to the equivalent of a 1 lb. coffee. So I need 12 or 6 scoops? I'm confused there.
