Hi - I have a Compool to EasyTouch upgraded system (no salt cell transformer). Is my best choice to get an Intelliclor, or are there other options that would integrate with my automation? Thanks.
The Intellichlor will integrate with your system and you will be able to change % settings on the IC at 1% intervals.
Any other SWCG you will be able to schedule for it to turn on and off via a relay. But you will not be able to control the % settings of generation through the ET.
You will have to buy the External power supply and the salt cell.. The cell needs to be rated for at least 2 x the volume of your pool. I would go with the IC40..
