- Apr 21, 2021
- 166
- Plaster
- Pentair Intellichlor IC-40
I searched here but what I got did not help me. I have a 4 year old Pentair valve actuator (outflow spa vs Returns) that is having trouble turning. It gets to around 5-10 degrees the motor is on but the valve makes clicking sound. I applied a little turning pressure to the handle and then got it to go until it gets around 90 degrees. Again, with a little encouragement I can get it to go to 170 degrees, where it stops and clicks again. It is consistent on where it stops.
Just so you know I've searched the site:
I tried the actuator section here, and found that the manual override (switch off) that works apparently on Jandy (loosen handle locking knob full full turns and push down) does not work on Pentair. Pushing down does not do anything; it won't push down at all. There are threads about lubrication, but no pictures on exactly where plumbers grease should be applied. Do I have to take the actuator completely off to apply the lube lubrication? I only took off top cover just now.
Help! You guys have always been so helpful here to me, and I need you again.
Greg
Greg
