I have Pentair EasyTouch control system with IntelliPH acid dispenser and Intellichlor IC40 SWG. I recently performed a pump head tube replacement on the IntelliPH. Shortly after doing so I noticed no power to my IC40. Upon further review I noticed the 12amp Intellichlor breaker was tripped. I reset and 10-20 minutes later it trips.
My system is about 4 years old now and the IC40 is only 10 months old. I checked voltage to the salt board inside the EasyTouch cabinet and it shows about 32 volts which is in perfect range. The small LED on the board is showing green. My repair tech thinks it's the IC40 but when I reset the breaker it (IC40) shows all green and passes the diagnostic test. At the same time he thinks the connector on the back of the IntelliPH is burnt. I really don't see where it's burnt. He's been wrong on other occasions and I think he's wrong this time. He insists that if the breaker is tripping it's the IC40. My gut tells me it's the salt board. I'm wondering what others think. BTW, I won't be using this guy anymore since he had no idea the IntelliPH and Intellichlor IC40 are all connected together.
