So I have been talking to a couple PB's but the one who stands out thus far uses Jandy equipment and Anchor pool covers. I've done my research and even on the Anchor site I can't tell which of the solid pool covers is supposed to be better. One has straps, the other uses springs. You can get it with a pump or a mesh in the middle to allow water drainage. I am in the mid-atlantic what do you guys think?
2 other inquiries would be that they are not big fans of variable speed pumps, claiming that it would be running at a high speed most of the time. I wan to use a salt chlorinator by the way. They are also not big fans of heat pumps in our area. Reasons were that they use a lot of electricity and only heat up to ambient air temp. Can I get some anecdotal experience on both the variable pump and then heat pump, thanks?
