- Jul 21, 2013
- 65,120
- Plaster
- Pentair Intellichlor IC-60
By the way, is the pool unsafe to swim in while I'm doing all of this?
With test strips it is impossible to say. But you have been swimming in it so far without any problems.
Once we get accurate tests we can tell you that a pool is safe to swim when FC is below SLAM FC level for your CYA and you can see the bottom of the pool should it be necessary to rescue someone.
With high CYA it is doubtful your FC is higher then the SLAM FC for that CYA level.
