I figured there are several people in the same boat on this subject.
So, on a related note, I opened this weekend, and ran the pump for half a day, then tested this morning, after getting the water level right. This is my first season of opening after winterizing after installing last spring. My results were FC-5, pH 7.5, TA 100, CYA 60. Salt was 2300.
The app says to lower the pH to 7.2, and then aerate to increase pH. I also have to add salt. So, I am unsure about what to do first, and what is the best order to go in to get things correct. A little guidance would be great. Also, one of the gaskets on my filter seems to have a pinhole leak. Best to contact the manufacturer for a replacement, or just look at HD/Lowes or plumbing supply? Same with one of my unions at the pump. I don't want to overtighten, and I am curious if anyone uses nylon tape on union threads, or just loosen, check the gasket fit, and re-tighten? I stored the pump, filter and salt cell in the garage over the winter, so they may have dried out a little.
