See my previous post #55
For the liquid chlorine consumption question.
Yes, you must use a different separate dispenser for cal hypo.
Cya mostly only leaves the water through water replacement/exchange. There’s a good chance most of the cya you had before you closed is still there.
The exception is Very hot water (above 90 degrees) can degrade cya some & some people find they lose a little over the winter (possibly because of a certain bacteria if the fc goes too low).
If cya is low you can add it separately or use a couple Trichlor pucks- the point is to test & know what you need then add it while understanding the effects it will have on all your parameters - not just blindly use this product or that.
That is extremely helpful it really clarifies the following question I was going to ask you - so read on but I see that you answered it above--
So now that I will be using BOTH products with NO CYA (stabilizer in it- HOW will my CHLORINE be protected from the sunlight? and preserved to be more effective? Remember that there will be NO CYA to preserve or protect it. And lastly with the newly used Liquid shock- do I STILL need to use the floating tabs daily? And again- since the Liquid shock has NO CYA-
should I
1)only use NON stabilized tabs
2) Use ONLY stabilized tabs?
3) Alternate based on the test results between
them both.
But as you stated above- I think option 3 that I just posted is the proper thing to do- since the test results will tell me if I do NEED to raise the CYA in order to protect the chlorine so to speak. otherwise, I would use the NON-stabilized type. This answer was really helpful.--
do you think this is a good idea as you have stated above?
lastly, I am attaching your post #55 about chlorine consumption and let me know If I am thinking right here--
This is your post reply------
The 5ppm is until you can test properly.
Average fc loss in algae free properly balanced residential pool is 2-5 ppm/day most falling somewhere in the middle most of the time. In your area of the world it’s not likely 5ppm for long except during the dog days of summer. For instance I am in the south & I’m heading into the middle of my season with 80 degree water temps & hot high uv days , my daily loss is currently about 3ppm.
Here is my question- I am looking at the Pool Math app and plugged in 10% chlorine product from Ace Hardware stores. I put in a current chlorine level of "6"( not sure why)- and I put in a target value of "8"-not sure why)- The result it comes up with is to use 28 ounces to do this PPM raise-- that would take the gallon 4.5 days to be used up- that is about $10 per week - am I thinking wrong here? Unless the fc exactly equals the target value then I would need no liquid shock. But that I think is a perfect world ??
I want to thank you all for the amazing help- it is quite late in NY - I will read the results in the AM- thank you people and have a pleasant evening.
