I am working on a pool for a friend who is out of state and can't take care of it.
Statistics on this pool:
21x43 oval above ground
vinyl liner
21,311 gallons
2hp Aquqa Pro variable speed pump
24", 300# sand filter
inline SWG connected but not in use during opening/SLAM
There is a large heater also, but we won't be worried about that.
I have no "history" of what was put in the pool in the past because my friend just bought the house. Given the array of pool "supplies" left by the previous owner in the garage (3" pucks, algaecide, etc, etc, etc) I'm thinking it wasn't any method taught here on TFP!
I opened the pool to a green mess. I even had to scoop a couple of dead things out of the water. I had to add a lot of water in order to run the pump. Once I could turn on the pump, I added 4 gallons of 12% LC to get the process going. I did see a change in the right direction overnight. That was a couple of days ago.
Latest Test Results with new TF-100 test kit are:
CYA 0 (will add using sock method according to Pool Math)
CH 100
TA 200
Before I start the SLAM, should I adjust the CH or TA? If so, how?
The water sample I used to test was over 24 hours old, so I did not test the PH yet.
Should I test the PH of a green pool or just adjust it after I SLAM it?
Thanks for your help! @mknauss @Texas Splash
vinyl liner
21,311 gallons
CH 100
TA 200
