Old Heater Gas Conversion
You should just need the correct size orifice to swap out in the burner. I can’t imagine a pool heater being any different than any other type of gas appliance.
Good Morning:
Has anyone successfully converted an older Jandy Lite 2 (2008) from propane to natural gas? If so what parts are needed. Thank you.
A 16 year old heater would have to be in excellent condition before one should even try.
Different main valve (+/- $150.00), different pilot burner ($100.00 and up), different burner orifices (about $15.00/@), different Honeywell ignition control (though you can use the one for propane). It will lock out after 3 tries with failed ignition requiring a power-off reset.
