Ohhhhh...
I'm not sure I follow the intent of what you are trying to do :unsure:
I thought SWG was to be left off during SLAM as it is unlikely to be able to satisfy FC demand.
If you are still slamming?
I'm not SLAMing. I just got over one. I have had to SLAM twice because my SWG isn't working n my PB says it is. So I'm done SLAMing just to prove to him next week my SWG is not working.
Reactions: RookiePick
Why not do an overnight gain test?
I think @Casey did and gained 0.5ppm. which is way unders for her cell/pool size at 100%, if she is not battling anything that would be consuming FC in the dark.
She's short at least 2ppm FC by pool math (should add approx 2.8ppm every 8 hours at full noise) on her 1.2lb/day AP1400.
EDIT - MY BAD. I THINK CASEYS CELL IS ONLY THE 0.92lb/day CELL. She is still well short on overnight FC gain though 🤔
Reactions: Casey
Did you change anything from where you were were the other day 100% output, pump 24/7?
Nothing. I just let it go. Only true difference was not removing my solar blanket because I've been working last 4 days.
