It’s all funny when you already have a spa to sit in....Hjahahaha
Thanks. I’ll get the hoses ready now! Will have two hoses running full steam. No work for a few days so i’ll Be watching all night. Brushes and 20 year old daughter are on standby. Grandkids will probably use school as an excuse to avoid the brushes this week.SWEET!!!! It IS happening!
Here is your "job" wrap something over the end of the hoses you will be using. A thick sock or two will work. You can use tape to hold it on. This will protect yoru new plaster from the metal on the hose and help filter the water some. Make sure the hoses are put RIGHT by the main drain. Fill the spa last. You do not want to take any chance of it running over onto the new plaster. It could cause streaking.
Do NOT stop the water from filling once it gets started! You can slow it down some if the timing of it being filled will be in the middle of the morning.
Get your shoulders ready for brushing your newbabypool! Try for two times a day.
Kim![]()
I wonder how many gallons it ends up being? That thing looks BIG! And oh so pretty!!
Your following directions is spot on! I see you even added bottles so the hoses can float. Nice extra touch!
How full is it this morning? Do you want to fly me out there to watch it for you?? :slidehalo:
I hope you have B on speed dial!
Kim![]()
A couple of pool brushings and it looks like a swamp. Stirring up a lot of plaster dust.
Chemistry is starting to get close to targets.
PH 7.8
TA 190 with a target of 300.
I was limping along adding fairly small portions of baking soda today. Getting more aggressive. I’ll get 300 this evening.
Sent you a PMDo you have a sub contractor list? I’m looking to replaster and can’t seem to find anyone that does plaster. I’m out by lone mountain.
Only during brushing. Water looks decent. Actually very little dust during last brushing this evening.Odd that you're seeing so much dust. It's enough to make the entire pool cloudy?
PH- 7.8
TA- 300
