Thanks Brian,You don't need to worry about the chlorine level until you discontinue the pucks. Once the startup is over you can add salt, cya and mange the pool based off the recommended levels.
If for some reason you want to add cya and raise the chlorine level now, there is nothing wrong with that either
I’ll leave the chlorine and CYA alone. 11 days in and the process has been no problem (With your expertise). PH continues to rise to 8.0-8.2 (Target 7.8) both during the day and over night. Still using approximately 1/2 gallon of 29% MA each day. I have been using JamieP’s thread as a gauge to my progress. What targets are we looking for to determine that the startup is over?
