Yep, no worries about the water in there. No matter how ugly it gets, it will be fine. No worries at all. Like Suz says, you should be concerned and it's good you are. All that will be cleaned up when it's time.
Big Will it is nerve racking to say the least...
Is this normal?
You can tell that there is a certain group of TFP builders that are all wired the same way. You, me, Will, Shantelly, etc are all new blood in that group...
Our water has a high tendency to scale as I'm sure you've seen in the shower, coffee pot, etc. I've seen people have to replaster their pool after a year or two in DFW due to not managing their water chemistry. Unfortunately, we have to learn how to manage our CSI to get a long life out of our plaster pools. Maintain CSI between -0.3 and 0 to prevent scaling in the pool and the SWG cell. Also, this winter be sure not to let CSI drop below -0.6 over winter to prevent etching. I have fairly significant etching in my pool from the first winter with low CH.
PoolMath will give you your CSI calculation after you enter all of ylur test results. Tweak pH and TA to move the CSI. Here is how to lower TA, Pool School - Lower Total Alkalinity. I'm lowering my TA right now. You will want TA 50-60 and pH right at 7.8.
More here, Pool School - Calcium Scaling
And here, Pool School - Water Balance for SWGs
That will be easy water to work with! We will work on the tweaks once you get your water in the pool. I have a set of links set up for new pool owners. I will share them with you when you get to the gunite stage.
For right now write these numbers down and put them in your test box so you can reference them over time.
Now go mow that grass LOL
Kim![]()
CLIFF! They got a LOT done! WOW! Look at how they spaced the different colors out!
LOL on the spot lights over the pad! Well done! You will be able to see things there at night for sure!
I am loving the time line! SO CLOSE!!!
Kim![]()
