- May 9, 2021
- 2
- Vinyl
- Hayward Aqua Rite (T-15)
Hi All,
As I prepare for my first closing on my own, I've been reading up on what to put in my skimmer. My PB closed the pool last year and used these 16ish inch Skim Insure gizmo-like tubes (https://www.amazon.com/CMP-Blowout-Winter-Skimmer-Guard/dp/B005IZPJB2). They worked well (you can blow out the suction lines with them in place and pour antifreeze through them into the line), you just have to make sure the water level doesn't rise over them since they don't seal at the top. In theory these should be enough to take care of any ice expansion in the skimmer, but I see that folks often use cut up noodles and plastic bottles with antifreeze in them to help absorb ice expansion. I was thinking of adding noodle pieces or a bottle, but I'm not clear on how it will work.
Most of the posts I saw seemed to indicate you just throw the noodle pieces or bottle into the skimmer and you're done. The part I'm not getting is how does a bottle or noodle that's going to float on top of any water that gets in the skimmer going to protect against the ice? Won't the bottom section of the skimmer (assuming no gizmo) be unprotected by the bottle or noodle since the bottle or noodle will rise to the top of the skimmer with the water before it freezes? Are people packing the skimmer so full of noodle pieces there is no room for ice? I doubt I'd be able to find the perfect size bottle or set of bottles that will run from the top to the bottom of the skimmer and fit along size of the gizmo (without pushing on it and potentially popping it out).
What am I missing?
Thanks in advance! And thanks for supporting such an awesome community! Tons of great info here!
What am I missing?
