- Jun 24, 2021
- 16,869
- Vinyl
- CircuPool RJ-60 Plus
Did you add 8 pounds of dry acid or 8 pounds of stabilizer?Monday calculated and added 8lbs of dry acid to achieve a CYA of 30 in a 28k gallon pool.
Tuesday nights test resulted in 40 CYA in my now 22k gallon pool.
Nice catchDid you add 8 pounds of dry acid or 8 pounds of stabilizer?
Two vastly different chemicals.
It is recommended NOT to use dry acid in a pool with a SWG.
He is in SLAM process. He is not adjusting anything but FC. He had pool volume off, which we spent the last page sorting out. He did addition at start of slam with a larger pool volume, which meant he added 40ppm instead of 30. We are good...And if you are in the SLAM Process, why are you adjusting any levels except FC?
Dry stabilizer in socks, go back a few pages and you can see his rig...Exactly what product did you add?
How did you add it?
Ok, great!He is in SLAM process. He is not adjusting anything but FC. He had pool volume off, which we spent the last page sorting out. He did addition at start of slam with a larger pool volume, which meant he added 40ppm instead of 30. We are good...
The target doesnt matter, only the actual. You can't lose what you didnt have in the first place.Do I have an OCLT of 0.5? Math says yes but I never reached my target of 16.
I wouldn't. Between rain and evaporation it'll always dance at least that much. 2 inches for me is 1000 gallons with a 20x40 so 750ish for you ?Should I add 500 gallons to my pool volume in the app?
I agree with @Newdude Right now, you are overshooting with your additions...that means your pool volume is LESS than the 22K. Probably your shelf/steps account for a bit less volume. I'd leave it. It gives you a bit of skoosh with degraded chlorine etc.Should I add 500 gallons to my pool volume in the app?
SWG gets here this afternoon, cant wait.The target doesnt matter, only the actual. You can't lose what you didnt have in the first place.
So you started with 15 and ended at 14.5. The also 0.5 CCs makes it a no question pass, so long as the water and all the surfaces are TFP clear.
Then you get slightly degraded bottles of bleach to be off further at times. Don't worry, you'll be a former jug lugger soon. Welcome back to SWG club.![]()
I calculated my pool steps/shelf to be 500 gallons. I'll add pics tonight.I agree with @Newdude Right now, you are overshooting with your additions...that means your pool volume is LESS than the 22K. Probably your shelf/steps account for a bit less volume. I'd leave it. It gives you a bit of skoosh with degraded chlorine etc.
All good!
Reminder, always follow this now, and keep your FC at the top of the range. FC up to and including SLAM level is perfectly safe: Link-->FC/CYA Levels
From Tabs and high CYA to now...Look at you. We want pics of this pool!
Post up too...Link-->How Clear is TFP Clear?
24 hours.How long should I wait to test after adding salt?
Right.My test Tuesday evening is wrong, probably did not circulate enough before testing.
Nope, circulation and test error.And quality of salt does matter. First 4 bags were SureSoft from Homedepot, next 6 were Diamond Crystal Splash Ready
I'll get 6 more bags tonight (probably need 5) and continue bottle feeding LC until I get a salt test in the 3000's after a 24hr wait. Then fire up the SWGBrush until its dissolved then wait 24 hours of mixing minimum. Most of us wait 48 hours of mixing before trusting the last add.
Any 100% pure bag is the same.
Am I the only one who has trouble getting a confident CYA reading? I even went and bought a bottle of the R-7065 CYA standard, which should yield a 50 reading, but I can still see the dot at 50. I read the R-7065 at 40, when the dot disappears.How did CYA change? There is no new test logged. What additional 10 CYA?
?? I thought stabilizer is a dry acid?Did you add 8 pounds of dry acid or 8 pounds of stabilizer?
Have a read:So then, based on what I see of a "faint dot" when I fill the tube to the 50 mark with R-7065 @ 50% with reagent, then I have to try to guess when the dot reaches similar "faintness" during the pool water test. You'd think someone could come up with a better system.
Dry Acid is sodium bisulfate, is used to lower pH and should not be used in a pool.I added directly to my skimmer, as directed. There were no warnings about using this with SWG, so hoping I didn't shorten the life of a brand new RJ-45+.
