- Jun 24, 2021
- 16,609
- Vinyl
- CircuPool RJ-60 Plus
Did you add 8 pounds of dry acid or 8 pounds of stabilizer?Monday calculated and added 8lbs of dry acid to achieve a CYA of 30 in a 28k gallon pool.
Tuesday nights test resulted in 40 CYA in my now 22k gallon pool.
Nice catchDid you add 8 pounds of dry acid or 8 pounds of stabilizer?
Two vastly different chemicals.
It is recommended NOT to use dry acid in a pool with a SWG.
He is in SLAM process. He is not adjusting anything but FC. He had pool volume off, which we spent the last page sorting out. He did addition at start of slam with a larger pool volume, which meant he added 40ppm instead of 30. We are good...And if you are in the SLAM Process, why are you adjusting any levels except FC?
Dry stabilizer in socks, go back a few pages and you can see his rig...Exactly what product did you add?
How did you add it?
Ok, great!He is in SLAM process. He is not adjusting anything but FC. He had pool volume off, which we spent the last page sorting out. He did addition at start of slam with a larger pool volume, which meant he added 40ppm instead of 30. We are good...
