- Jul 15, 2012
- 634
- Plaster
- Hayward Aqua Rite (T-15)
My 22 year old pool was just resurfaced for the second time (did it last in 2011). My PB applied bond-kote two weeks ago and finished with application of Midnight Blue Diamond Brite yesterday in both the pool and spa. He left me to pick it from here, with well water filling in the pool. Bit he did return today to add acid (a lot of it) to expose the Diamond Brite. My instructions are let it sit overnight and to start the circulation tomorrow or Wednesday (the pool filled faster than he expected), being sure to record my chemistry on a daily basis. I am to run the pump 24/7 for a few days, then eventually to balance system and set to timer. No pool vac for a month. And I should brush the walls and floor daily for two weeks.
I measured the pH just now at dusk and its very very low - spa is 1.5 and pool is 2.2 using digital pH meter (just calibrated). He put a helluva lot of acid in. I am very reluctant to open my pool circulation while the pH is this low. There is no cutoff for my RayPak heaters (model 406, 400,000 btu, from 2012, one each for pool and spa on separate circulation systems) and the acid will destroy them. Right now I still have the plugs in from winterization. Do I neutralize the acid before I turn on circulation? If so, how do I circulate the chemicals I add?
His target chemistry is pH 6.8 for a week, then let it run to 7.4-7.6. Target CH is 200-400. He says no chlorine for at least a few days to a week. Temps are still low-mid 60s on warm days and 40s at night, so I doubt much algae will grow just yet.
Thoughts on pH rated issues and my pool heaters? Also, thinking I should add Jack's Magic Pink in case there was iron in my well water. Thoughts?
Many thanks. I did my own pool maintenance last years since June but this is the first time I have started up a pool.
