Hello: I purchased a 24x12 Intex ultra salt water system pool. I levelled the ground using a 2 X 12 and a 3 foot level. seems pretty close. I figured Id get it closer when the walls and legs are up without water.
-I want to use the pink insulation and 2 x 12 pieces under the legs.
-I ordered the TF 100 test kit with the saltwater kit and the stirrer. Just ordered. Im east coast so, I assume a week.
-Should I get my tap water tested at a pool supply store and then use the pool calculator. Im assuming the directions will tell me how much salt to use. Then I'm reading to use the directions on here. Any links? I can't find them.
Rob
Rob
