You can also get a gizmo to put in the return hole on the water side.
Make sure to put something on the ground around the skimmer. Water IS going to splash out from over full from rain or happy playing. You do NOT want to wash that dirt you worked on so hard out. I used a couple of steppers and made sure to angle them oh so slightly away from the wall to the water went away.
Chemicals-Run an almost full test (all EXCEPT CYA as that has to be added). Post up the results here like this:
FC
CC
pH
TA
CH (does not really matter but go ahead and run it)
CYA
We will guide you on the next step from there.
FC
CC
pH
TA
CYA
