- Sep 4, 2022
- 333
- Plaster
- Pentair Intellichlor IC-40
It's been a while since I posted, largely delayed due to rotator cuff surgery and initial recovery, here is a long overdue update.
Still holding for plaster until the backyard hardscape/landscape is complete. The hardscape contractor mobilized on 12-7 so we are one month into the progress. I just updated my youtube channel with a hardscape video timelapse. Hardscape contractor mobilized on Dec 7th and they are a little more than halfway done.
Check it out if you're curious how the backyard work progresses.
Backyard should be done by the end of January and plaster is being planned for February 26th.
My current to-do list is below, missing anything?
- Paint back of feature wall and equipment screening walls
- Install gates on equipment screening wall and punch list items for fence
- Install auto close on our 0XX0 sliders and flip door handle and deadbolt on patio door (confirmed that with latch location bedroom windows don't need stops)
- Clean up mortar below waterline tile and apply waterproofing immediately below waterline tile to cover mortar
- Bond fire bowls to pool bond wire
- Call for final pool inspection
- Start research to get familiar with startup and ongoing chemical maintenance. Write out startup plan and ongoing maintenance schedule/plan (I have the mfg plaster start-up document). My reading list includes Pool Care Basics Archives, Just Filled Your Pool with Water? Here's What To Do Next - Further Reading, , Start-up New Plaster, any other key resources?
- Order TFP Pro test kit and test fill water
- Order attachments for my protuff pole (I figured I better spend the money on a lifetime pole now, it doesn't feel like much with all the $$ that are flying out of our bank right now)
- Get Intellicenter up and running on the network and update software/firmware (whatever is needed)
- Get pool chemicals (liquid chlorine, muriatic acid, CYA, salt, etc)
- Plaster
- Order robot, any recommendations? (this is a whole other area to get lost in doing research)
- Related by not needed for the pool at this time includes two remaining gas inspections and replace gas meter.
It's been a while, are you still interested in feedback? DM me if so. I have a large contractor list that I did some research on that I would be happy to share as well.after your build is complete I would appreciate any feedback you have on specific contractors used, and whether you'd recommend or not.
