Ladies and Gentlemen, boys and girls, AH-64 Apache attack helicopters……
It’s that time of year again with an influx of newbs either getting a late start or coming to us trying to undo what hasn’t been working. First of all, I’d like to welcome you all. You’re gonna love it here. We will help you maintain a pool the stupid easy and even stupid-er cheap way.
We’ve likely told you that you need a reliable test kit, but they seem so scary. You meander over to pool school to see what it entails, and although it’s simply and exactly written, it seems like rocket science and you are in way over your head. We throw terms all back and forth that are Greek to you. Take your R-0871 and and swirl drops with R-0870 in the 10ml vial and whatnot. Many many folks are overwhelmed and remember failing chemistry. (Side note, I don’t believe everyone failed chemistry that says they did at this point, but I still LOVE the jokes myself).
So, while the test kits come with a cheat sheet and the same instructions are very simply laid out in pool school, I want to break it down further so you can realize how stupid easy it all is. We were in your shoes. We were all overwhelmed when we were there. We all finally sucked it up and tried…….. and 3 tries later we *facepalmed*.
For starters I will take the all important FC test that will be done the most frequently. If we can convince you that you can easily do it, you’ll understand better that ALL the tests are just as easy. Each is a little different, and they all have their own quirks/hacks, but first we have to get you over the hump to try.
If you look at the instructions as a whole it’s insane. Stop right there. Use your hands, or paper, to block off everything but the FC test. Oooooooh. That’s much better already. Ok now, here we go. One step at a time. Scan that test for which supplies you need. No need to care what each one means yet. We will get there later. Just get the supplies listed as their reagent #. For FC it’s R-0870, R-0871 and R-0003. Stupid easy to find the bottles, right ? Get them together and here we go. Ignore all the other bottles for now.
1) rinse and fill vial to 10ml. Ok ? I can do that
2) add heaping scoop of R-0870 powder. Ooooooook ? I guess that’s easy enough.
*still skeptical*. *probably grimmacing now*
*vial turns hot pink*
Ooooooooh. Prettttttttttty. What a lovely shade. Pay attention you dolts !!! This is SERIOUS STUFF !!!!
3). add R-0871, one drop at a time, 1-2 seconds apart, swirl and count. *now grimacing that you are halfway through and it’s all been so easy*.
4). When solution turns clear, stop. *facepalms at how stupid easy this all really is*
5) divide drops by 2 for FC. ( ie, 10 drops = 5 FC). *throws instruction card because they doubted themselves*. *has tantrum*.
We still need to check for CCs but you’re a LEGIT scientist now. Pffffffffft. *grabs bottle of R-0003*
6). Add 5 drops of R-0003. Why !!! Why did I doubt myself ??? I’m SO stupid that I thought I’d be stupid !!! ARRRRRRGH !!!
7). If solution stays clear, no CCs. If it goes pink again, add drops of R-0871 and same as FC, Count and Divide by 2 for CCs.
BOOM. Done. Look at you go !!!!
It is *that* stupid easy
