Assuming that CYA level is correct, which you should confirm when you get your own test kit, you need to drain some 70%-80% of your pool. That can risk it popping out of the ground.
Read about our No Drain Water Exchange process at
Draining - Further Reading
And your CYA level may be higher then 180 as pool store tests have limits as to how high they can go and they report the highest number their test goes to.
When you get your own test kit then...
For cold water (<70F), let CYA sample warm up first.
For CYA anticipated <90ppm:
- Put sample in mixing bottle (up to the mark, ~ halfway).
- Add an equal amount of R-0013.
- Shake about 30 sec; let stand 2-3 minutes; briefly shake again.
- Glance into C.A VIEW TUBE, slowly pour mixture in until the black dot is not seen when you glance in. Do not look for the dot. Natural indirect light gives the best readings.
- Gradation closest to the fill level is CYA.
After reading, pour mixture back into the mixing bottle and try step 4 again; repeated readings on the same sample will lend confidence in the result.
CYA > 90 dilution Test
For CYA > 90ppm, repeat the test adjusting the procedure as follows:
- Fill the mixing bottle to the lower mark (15 ml line) with pool water.
- Continue filling the mixing bottle to the upper mark (30 ml line) with tap water.
- Shake briefly to mix.
- Pour off half of the contents of the mixing bottle, so it is again filled to the lower mark (15 ml line).
- Continue the test normally from adding R-0013, but multiply the final result by two.
If you need to dilute the pool water further then apply these ratios:
Pool water | Tap or distilled water | Multiply result by |
1 | 1 | 2 |
1 | 2 | 3 |
1 | 4 | 5 |
Note that when doing a diluted test not only do you multiply the range of the test you multiply the error rate of the test, so results are a ballpark - not an absolute.
See
CYA Testing for tips in how to read the test results.
Test Kits Compared
