Also whoever came up with the solution to buy the pack of 100 hairnets on Amazon and use these as skimmer socks is a genius. I kept probably a hundred thousand or more bugs out of my filter last night from this and they are cheap!
I have been a member going on 8 years, and had not tried the hairnet in the skimmer until this year. It is a game changer over use of the expensive skimmer socks, work just as well, and easier to put on and pull out when full. That's one of the many reasons why:Also whoever came up with the solution to buy the pack of 100 hairnets on Amazon and use these as skimmer socks is a genius. I kept probably a hundred thousand or more bugs out of my filter last night from this and they are cheap!
Good to have extra but you may want to consider how much to buy at one time. Realize, chlorine degrades faster in heat and sun. So make sure you store them somewhere out of the sun. If the temps outside are getting hot in your area (not in mine grrrr) then store it inside.I ordered as many bottles of chlorine as I could . . . . . My plan is to get at least 12-14 bottles right now and more when I run low.
Something to consider:You got it sir! PoolMath says 3.5 jugs for 12ppm, should I go for 4?
When you start the SLAM, (shock level and maintain) it's very important to keep the FC at or above shock level at all times for the SLAM to be the most effective. Every hour test and get the FC up until levels stop dropping quickly, then you can test and add FC less frequently. If FC stays below SLAM levels for any period of time, it slows the process.
So with all that said, unless you're at home babysitting that pool, you can't keep FC levels at SLAM constantly. Therefore, it's not a bad idea to bring your FC several numbers higher than the SLAM levels if you can't keep testing frequently throughout the day.
Don't forget to brush, brush, brush too.It gets that algae off the surfaces and moving which kills it faster.
Great!Thank you! So I guess I'll be adding chlorine in the morning then. The bottles will be stored in the garage (no windows) and right now for the next week or so it won't be very warm at all up here. Yesterday the high was less than 60.
It is not recommended to raise your FC above SLAM level by any appreciable amount. The excess FC will burn off due to UV quite rapidly and there is the chance of damaging the vinyl liner.Therefore, it's not a bad idea to bring your FC several numbers higher than the SLAM levels if you can't keep testing frequently throughout the day.
I'll have to remember that. Thanks for the update/correction.It is not recommended to raise your FC above SLAM level by any appreciable amount. The excess FC will burn off due to UV quite rapidly and there is the chance of damaging the vinyl liner.
As long as the FC is above minimum, it is killing algae, albeit not as quickly as if it is at SLAM level.
That is the minimum. It will take a lot longer to complete the SLAM, but it is what it is.
No one at the house to dump in some chlorine mid-day?
Nah, she could just leave that job for you . . . .But that means teaching her how to remove and replace the cartridge too. lol
