- Nov 17, 2020
- 6
- Plaster
- Hayward Aqua Rite Pro (T-15)
Closing on a house in the Charlotte, NC area on Monday that has a pool. During our last visit, middle of September, we had a pool inspection performed. The kidney shaped pool is approximately 21k gallons gunnite in-ground. The pool has two pumps, a Hayward Super Pump that is 2.5 hp for the main pool and a booster pump, also 2.5 hp with a motor from AO Smith. The filter area looks like the Super Pump. It has an Aquarite Salt System with a T-Cell 15, a Hayward H400 heater, Hayward sand filter and an Aqua Logic Automation system.
Only the main pool pump was working properly. The sand filter was leaking at the valve and backwash hose.
The equipment resides about 60 feet from the far end of the pool where the spa is and the closest part of the pool is within 20 feet of the equipment. Widest point is about 17 feet and the narrowest point is about 10 feet. The length is 33 feet with a 7 foot depth and a 3 foot shallow end with a small area that is barely under water.
Questions I have include the following:
1. Based on the calculations I've seen for HP I think a 1 hp VSP would be sufficient. Does that seem correct?
2. The TCell-15 appears to be for a 40k gallon pool. Is there a reason I should replace this Tcell with the same size or move to the 25k gallon pool size?
3. Since the Hayward Super Pump seems to be working, should I just move that pump to the spa and replace the main pool pump with a VSP?
4. Should I consider getting an entirely new SWG system or try to replace the board and the TCell to start?
5. Should I do anything with the Aqua Logic Automation system? If so, what should I consider doing there?
Thanks!
Thanks!
