OK, my 1.5 HP Hayward Superpump kicked the bucket. I am replacing with the Hayward W3SP3215X20XE TriStar XE Ultra-High Efficiency Pool Pump, 2.25THP, 230/115V. Any suggestions on speeds and run times before I install it?
Find the minimum rpm needed to run the SWCG. Add a couple hundred rpm. Then determine how long you need to run it to create the chlorine you need each day. That is your minimum. From there, does it skim the water properly? If so, you have found your needed rpm and run time.
You have a sand filter so maybe add a bit more rpm - once the filter gets dirty your flow rate will drop. Or else do the flow rate test with a clean filter and a dirty filter and choose the higher rpm
OK, great. Took my lunch break to get it plumbed and wired up. I'm letting it sit for a while so the PVC glue will harden. I would like set it up to run X amount of hours and off Y amount of hours so I need to read up on it and figure it all out. Thanks.
OK, bit of a problem. I bought a 2" to 1.5" reducer to connect my 1.5" to the new pump. And now I have water pouring out of the pump at the reducer. I guess I should have used 2" pipe for a bit then necked it down. Is there a way to salvage the Union Connector or do I need to buy one at the hardware store?
No, I glued it all but those reducers were 2" to 1.5" reducers (https://www.lowes.com/pd/Charlotte-Pipe-2-IN-X-1-1-2-IN-SCH40-REDUCER-BUSHING/5012474889) and they free spun in the 2" connectors provided by Hayward. I learned my lesson and purchased two more connectors from a pool store and run 2" pipe into those connectors. My only worry right now is I have the 2" pipe necked down to 1.5" pipe with a DWV reducer. So far it's running fine with no leaks.
