Hey all,
I am in NJ and just moved into a house with an in ground pool. 18x36 with 25K gallons. I just had a new liner put in about a week ago. I had the pool filled with 4 water trucks with 25K gallons of spring water. Water was 60 degrees, turned on heater and brought water up to 77. Water crystal clear. I brought my water to Leslie and had it tested. I do have test strips but thought they would be more accurate and I could purchase chemicals.
I used a powered shock they sell and some dry acid. Then I tested the water again and here is what the results were according to them.
Free Chlorine 0.38 ppm
Total Chlorine 0.46
PH 8.1
Total Alkalinity 250
Calcium hardness 190
Cyanuric Acid 11
Iron 0.1
Copper 0.2
Phosphates 0
TRDS 300
I have a vinyl liner pool, as I said brand new. Leslie Pool told me to use some Liquid Super shock. 2 gallons which I diluted and added into the pool last might. Filter has not been shut off for a week. The active ingredient is sodium hypochlorite 12.5%. I added nothing else last might at 7PM. This morning before work I took a look into the pool and it is milky white. Can't even see into the water. So 12 hours later. Did I hurt my new liner?
They also gave me muriatic acid and told me to add 2 gallons which I have not done. I now read you should not use this for a vinyl liner pool. Please help me learn. I have been reading and watching videos. I am hoping this site will become my go to and I can learn to take care of my pool myself.
I need how to proceed. I have cartridge filters, 2 of them. An inner and out filter which I replaced so they are brand new. The water so crystal clear up until last night. I really am hoping I did not do any damage to anything.
Thanks so much for the help all.
Brian
Total Chlorine 0.46
PH 8.1
Cyanuric Acid 11
Iron 0.1
Copper 0.2
Phosphates 0
TRDS 300
Brian
