I’ve been reading up.. and am nearly ready to start fixing/maintaining my new pool. It was built 3-4 months ago. Please could help me kick this off confidently?
Did my first test at a pool store and my results (image attached) are:
pH 8.4 (!) – from PoolMath app, add 0.3kg dry acid – should this be the first step?
Sunscreen 1 – (SWG Range CYA 30-50) – from PoolMath add CYA dry 2.2kg? How much time after first step to this one? Will this drop FC? Also, this is very hard to reduce right? So, should I retest to verify actual before buying/adding CYA?
FC 2.58 – seems ok? It will need CYA to stabilise value & Salt to improve production right? Then test everyday to adjust SWG run time?
Salt 3200 (SWG Range 4000-6000) – should I add Mineral or Regular salt? From PoolMath app add 75kg Salt. Seems a lot? Re-test before adding this or sounds about right?
Alkalinity 71 (SWG Range 80-150) – PoolMath app suggests target 50-90? What should I aim for?
Calcium 125 (SWG Range 200-275) – PoolMath app suggests target 350 by adding 7.5kg CaCl. Is this right?
I plan to buy the AussieGold 4in1 test and rely on pool store for CYA Salt reading etc. Yay or nay? Don’t know if Clearchoice $$$ is required. Please advise. (Edit: Tests from USA are hard to come by and expensive here in Australia)
Thanks so much in advance for your help & advice wonderful people!
