The acid demand test is supposed to tell you how much it will take to reach your target. The settings I gave you for PoolMath were assuming 8.0 pH - that may explain the difference.
That sounds like a lot of acid to me, but I don't usually use dry acid, so I'm not sure. At worst, you can start with 1000g and retest - the key here is that you don't want to overshoot and end up with a dangerously low pH.
