Pretty simple - use 5ml of water, each drop is 1ppm of FC (so 10 drops = 10 FC). It's key to make sure your sample is as close to be exactly 5 as possible for the least error (the bottom of the meniscus of water needs to be exactly on 5 while the sample container is on a level surface, and if you're going to do an OCLT, use the 10ml sample size instead.
