So exciting!! Looks great.
Hey, I don't see any lake near you?? Did they just make up the town name? Or is it an ancient lake area?
It's an ancient lake, so there's no lake here anymore, just a new pool that's almost complete
The pool equipment pad is now wired and ready to go. Notice we deleted the booster pump since we will be using a pool robot to clean the pool.
The pool builder will be spray painting the piping to match in with the filter and control panel.
One valve is manual and connected to the two skimmers and the pool vac line (we won't be using the pool vac connection, but I'll allow a small amount of water to be pulled
through the vac line to keep it clean.
The second valve is electronically controlled by the Pentair Intellitouch Control Panel so we can control the amount of water being sent back to the returns or direct more or less of it to the waterfall feature, when we need it.
Most of the time the waterfall will be off, but the electronic valve will direct more water to it when we want it running
Still need to add in a low voltage transformer for the low voltage landscaping lighting.
I'm planning to use a Low Voltage Intermatic safety transformer for all Landscape lighting which is pool rated to keep it all safe.
This will be controlled by one of the spare relays in the Pentair Intellitouch Control Panel
