Total noobie here, never owned a pool or maintained one.
Just starting out for the first time.
We looked at a number of pool contractors in the local area, got three bids and reviewed three vendors for a new pool construction.
Settled on a local builder with a good reputation and saw a number of examples of their work.
The pool will be an In Ground Gunite pool, with pebblesheen. Pool size is approximately 34 foot x 21 foot x 8 foot deep with 9" cabo at one end.
The pool will be about 600 sq feet of surface area.
In the attached diagram, North is directly to the left of the diagram and south is to the right (meaning the North / South orientation is Horizontal)
Putting down about 660 square feet of concrete decking around the pool
Will be using mostly Pentair equipment, for the filter, variable speed pump etc (have to dig out all the specs from the builder).
2 Skimmers
4 Returns
Pentair Intellitouch Control Panel
Pentair Quad DE 100 Filter
Pentair Racer Pool Cleaner
Pentair Intellifloxf Variable speed and flow pump
Pentair Booster Pump
The pool, will have a single multi-color LED light at the top of the pool (see diagram)
Jump Rock at the top left of the deepest part of the pool
3' x 5' Moss Rock Water fall, top right of the deepest part of the pool
4' shelf top left of the pool
5' bench under the water fall
5' wide and 5' depth CABO bottom left of the pool which will be 9" deep
We are in the design phase of the pool at this point and finalizing the design with the pool designer (see attached diagram of the pool)
Looking for any comments, gotchas, and things to be aware of as we go through the build process.
Go easy on me I'm a total noobie.
Here's the rough area (marked in RED paint) of the back garden where the pool will be installed:
2 Skimmers
4 Returns
