KBR
Active member
Congrats looks great! Do you mind posting some update pics after awhile? We’re doing Blue Surf as well, just curious how much the color changes after start up.
I sure will post pics as it continues to change to final color.Congrats looks great! Do you mind posting some update pics after awhile? We’re doing Blue Surf as well, just curious how much the color changes after start up.
You have no CYA if you didn’t add it. So there is nothing in the fill water to ‘see’Well, I went thru the entire mixture but it was just clear the entire way up the cylinder and I can easily see the black dot. Anyone know what I'm doing wrong? Is the mixture supposed to stay clear?
normally we say to be sure of your baseline before adding, and creep up to the target, but for once we are absolutely sure it’s 0. Add to 30 per PoolMath
Pucks add 1 or 2 ppm each and take 5 days to dissolve. Even if they were all in there now, you can’t read 20 or below. Add your own to 30 with the sock method.The PB filled my inline chlorinator with a few pucks and said it'll last about a week and then I can start my own process after the official startup is done next week.
Thanks dude!*don’t worry it all makes sense so much better when you are reading about it AND doing it. It will finally click and you will level up on the spot
That sounds impossible for me right now, haha...but that would be neat indeed!What will be neat is when you can just look at your water and know if the pH is low or high! I would test any ways just to know how much m.a. to add to it.
LoLanother funny is when you are looking out the window and do a double take because there is NO water to be seenRun out there to see the water is THAT clear and still so you cannot see it! Now that is TFP water!
Anywhere works but it’s heavier than water so always brush good wherever you add. Probably easier in the shallow end going forward. Also be aware of where you are brushing the possible chlorine puddle to as that area may need to be brushed to disperse the smaller puddle.so was it correct to put the chlorine/water mixture into the deep end
20 mule borax. $4 a 4 lb box in any laundry aisle. Put your TA and PH in pool math and it will guide you the rest of the way. Dump it in and brush away. You may need several tries as anything below 6.8 looks like 6.8. If your fill water was 5, it will still read low after adding. Once the pool has some time under it you will be battling high PH as the plaster cures. Maybe for months. It’s normal and just hit it with Muriatic Acid per pool math anytime it hits 8 PH.Also, I what about the other items like the low PH of 6.8, how do I increase that
Hang tight for a plaster pro.My CH is low too, but it's new plaster, I'm surprised it's not higher.
It only had to soak and it’s acid so the skimmer basket isn’t the best for your equipment. Hang it in the pool on a stick (in any old sock) and let it soak for a day. Tomorrow it will squeeze out in minutes. Bonus points if you swim it around to disperse the cloud. Don’t stick your head in the cloud and open your eyes, but it’s otherwise safe to be in.Finally, for increasing my CYA, I have a skimmer basket with a soft net around it...do I just place the CYA granulars in any old sock and put it in the skimmer basket, will it damage the net or basket
Thanks Dude!
My PH was on the high end before yesterday when the start-up guy came and he left saying he added 2 gallons on Muriatic Acid.
You think this caused the sudden drop in PH?
If so, I assume it'll creep back up like you said, so you think I can wait as opposed to adding Borax, or should I go ahead and add?
As for the CYA, what area or place does the stick hold onto in the pool to avoid it from drifting to the side walls of the pool and having it touching that the entire time while I'm not out there? If you have specific instructions of best methods, please let me know.
Low PH (particularly low) PH is the worst thing that can happen to your equipment, chemistry wise. Sure if an F-150 careens through the backyard……. Well. You know what I mean.You think this caused the sudden drop in PH? If so, I assume it'll creep back up like you said, so you think I can wait as opposed to adding Borax, or should I go ahead and add?
If the MA was 31% it would have lowered your pH by 3.5.
Yup.
With a TA of 80 and new plaster just wait and it will rise back up in a few days.
I don't see a heater in your signature?
Dangle the CYA sock in front of a return so the water flow from the return pushes the sock out.
20 mule borax in a small white cardboard box. Should be top shelf when you find it in the grocery store.Also, any particular brand of Borax I can get?
Weight the patio end of the pole / stick so the sock hangs out a foot or two. It just needs to soak. Doing it in front of a return helps disperse it, but it’s no harm to let it soak for a day without returns.As for the CYA, what area or place does the stick hold onto in the pool to avoid it from drifting to the side walls of the pool and having it touching that the entire time while I'm not out there? If you have specific instructions of best methods, please let me know
20-30 mins after mixing. Until you get the CYA up check a few times a day. The sun may eat all your FC in an hour or 3.Finally - How long do I wait until testing for Chlorine again after adding it
