AQUA~HOLICS
In The Industry
Again, it depends on the type of jet and plumbing design. Have you picked out the jets?
Ok. I haven’t decided on the spa jets yet. Do you recommend any jets assuming having separate pump and 3” line ? What Pentair pump is recommended ?Again, it depends on the type of jet and plumbing design. Have you picked out the jets?
Also, the blower is a crutch. It really only helps when the plumbing is designed incorrectly and the venturis don't have enough power to clear the air line. A properly designed spa should not require a blower.
Right. I need an arc instead of a trickle effect. My question was to get that arc how wide spillover need to be.If you see my photo, you can see our spa spill is 6 feet. I'm not sure what your issue is exactly. Rate of water into spa determines if water just trickles over or arcs a bit.
That is what I described in post #4.
As I mentioned before, if you can go with 1/4" jets (10 GPM each), then a single pump solution should work for 8 jets. But I would plan on a filter/heater bypass as well just to make sure. Make sure the PB uses 3" pipe.Ok. I haven’t decided on the spa jets yet. Do you recommend any jets assuming having separate pump and 3” line ? What Pentair pump is recommended ?
I would go with 2 pump solution. So I'm thinking pool and spa drains would be 3". Spa jets would be 3". Spa return(1) and pool return(6) to be 2 1/2". Pool size 18 * 36 and spa size 7 * 7.As I mentioned before, if you can go with 1/4" jets (10 GPM each), then a single pump solution should work for 8 jets. But I would plan on a filter/heater bypass as well just to make sure. Make sure the PB uses 3" pipe.
But personally, I would go with a 2 pump solution. It works much better. With 3" lines and a separate loop for just the jets and nothing else, you can go with 3/8" jets and an Intelliflo XF VS pump. The spa will need separate standard return lines for heating and filtering only.
Also, if the PB uses a Hartford loop or the grade from the spa to the pump is uphill, then you can possibly go without a blower.
How do I find prevailing wind ? Is there any website. I’m near Leander, TX. Skimmer is not close the spa, but it is close to tanning ledge and entry to the pool. Min depth is 3’6” and max is 8’.That would work. Have you looked at prevailing winds for summer in your area? The skimmer in corner by spa is a toss up. With no wind or good wind it will suck up all the gunk trapped in that corner. With the wrong wind it will just circulate water. And remember a standard return cant angle more than about 45 degrees but they do make right angle fittings that work excellent for certain situations. What's the depth specs on pool
