New pool Build in Arizona! Started today! Pics included!
Psycho1122
64
Mesa, AZ
Some nice solutions for pump / plumbing protection!!
I also addressed this issue with heat and UV. I had a unique situation that required a "custom" solution that allowed for airflow and shade. I am a firm believer in the "coolaroo" shades and their effectiveness. Here is my solution....
kimkats
44,900
Tallahassee, FL
LOVE IT!!!
Now here is your job.............put socks on the ends of the hoses to keep that pretty, new plaster safe from the metal ends. Put the end of the hoses right be the main drain cover. When you start the flow of water into the pool do NOT stop it!!! Stopping the flow could cause a ring around the plaster that is almost impossible to get out :(
Kim:kim:
  • Love
Reactions: CombatVet13
Psycho1122
64
Mesa, AZ
Ouch! I have read up on this condition prior to my Pebble finish going in last February. Do you know how long it took your crew to apply the finish? (Normal timeframe with pebble is 2-4 hours) Mine took just over two hours from first application to final exit. Did they "cover" your pool when it was applied? The proper method this time of year in AZ is to put up a cover to shade while the pebble is applied. The cracks are the first sign of future problems.
Take the advise of others, document everything and address the issue promptly with PB.
All the best...
onBalance
In The Industry
Jul 25, 2011
1,004
Utah
I don't consider that type of cracking as being normal. Also, I don't think that it is due to the hot sun, at least, not entirely. Some other problem must have occurred with that spot and area.
I concur with Brian that the cracking will probably not sufficiently and properly close up when filled. It should be repaired with additional plaster/cement material being applied and forced into the cracks. Hopefully that is the only spot or area that develops cracks. If more cracking areas develop, then there is an underlying problem.
