I've been a TFP member for about a decade now when my family first dived in literally that long ago.
We are now looking into a Hot Tub which I was happy to see there are plenty of forum posts. With the events that have happened in the last year plus, I have some questions to ensure the research I've seen on the forums here and elsewhere is up to date and try to consolidate some things for anyone years down the road to also view.
It appears that the state of the world has taken what was a $6000 range hot tub and turned it into a $9000 one.
Similarly what used to be 30-60 days to get a hot tub has turned into 3-6 months if not longer in many cases.
In general, what is the top five things to consider when researching a tub? What are the "be weary of this" items?
What are the pros and cons of these brands?
Marquis
CalSpa
Valley "My Touch"
Catalina
Everlast/Strong Spa (Sam's Club)
Essential (Amazon)
What importance is a galvanized frame over a wooden one?
Some tubs have a thicker/sturdier base foundation that may make it more sturdier to move and level no matter what concrete/pavers are under it. How important is the base?
Many tub upgrades include a "tray" that is used to hold Chlorine and some other item to feed/clean the tub. I plan on putting in an inline SWG myself (thank you TFP for that tip), so is that upgrade really needed?
Many tubs use spray foam. That sounds like a nightmare if you needed to work under the tub. Is the spray foam just like "great stuff" you can get a Lowes that can be replaced? Are the models with the reflector panels OK? How about the models that put foam in the perimeter walls like DuraWall from Everlast/Strong Spa?
I've done some DIY things to my pool like replace the pool pump motor, installed a SWG, plumbing etc. Is there a hot tub manufacture that is more "parts are easy to find and interchange" than others? Like 5-10 years from now, will I have to scavenge for exact controller boards and panels or are their common ones that can be used?
Is Acrylic for the tub a no brainer? Resin tubs seem to be available for less expensive, so what are the big cons their outside of appearance?
What about the tub surround? Resin vs the faux wood wraps?
Anyone get a tub from big box stores? Specifically the Everlast/Strong Spa collection from Sams Club. They have hit or miss reviews. Many of the reviews complain about support but as outlined above, I can fix many things myself if need to.
Any guidance of a new tub versus a used tub. If matters I am not looking used that is older than 5 years.
It appears there are many possible deals on used tubs. Moving it looks to be a bear even if I have 5-6 helpers and do moving tricks like roll it on schedule 40 pvc pipe. Someone will have to put the tub on its side for a little no matter what to get through my pool safety fence. I helped my neighbor move his years ago. I prefer to forget that experience.
Marquis
CalSpa
Valley "My Touch"
Catalina
Essential (Amazon)
